Any one have steering sticking problems issues on new Element XL?
Under speed on plane or just putting around? I find the steering sensitivity on the element to be very trim related. If you hit the right trim it turns easily at speed. If you are off by a bit, the steering gets noticeably harder. It's a fine line between easy steering and prop cavitation.
When just putting around...yeah...it takes a little muscle but I knew it didn't have power steering when I bought it.
My element xl only 2 years old and steering cable and throttle cable had to be replaced--$1200 (Bayliner wouldn't cover under my extended warranty Gold - 115HP). My trim kept acting up, finally removed the delimiter and working fine. My last boat lasted 20 years with few issues, this one not so good.
OB's can benefit from an aftermarket "upgrade"
The Steersman steering guard helps keep the cable lubed and the water out at the tilt tube area.2 PhotosDave
