79 Conquest 3250 charging system-gctid823873
    I need some advise on wiring the charging system on my '79 3250 conquest. It currently has a C-charge 5000 series 40 amp charger (which I think got fried over the weekend). It is currently powered from A/C inputs from Onan 6.5Kw MCCK genset control panel and has 3 DC outputs, one is going back to the generator battery and the other two are wired into a 3 way perk switch. I have 3 perks, one for each motor (on and off) and the 3rd has A/B and all. Why do I need the 3rd perk and it's function and is this the best way to wire and run it. I've been having issues for quite some time and want to redo the system correctly. Thank you for any input and or suggestions.
    [map type=HYBRID zoom=2][/map]
