Automating boat freeze protection - A new heater hits the market.
    Some of us live in areas that freeze in the winter. What if you want to use your boat in the winter? How do you keep your boat warm, and also know for sure that your boat is not freezing up, if you are away?
    Well, there is ow a single stop solution for that!
    Wallas, a major manufacturer of diesel based forced air heaters now has a line of boat heaters that are wifi compatible and even have a app so that you can not only start and stop your heater, they also have just as important the ability to see how your heater is working.
    Scan Marine in Seattle is the distributor and I think this is the perfect solution to boaters that live in at risk areas, and still want to use their boats
    What do you think of this?
