bad light switch?
    bad light switch?
    Finally received the led lights i ordered. Took a lot of searching to find led that work on ac to replace my hallogen pin socket lights. These are not quite as bright, more like 35w compared to 50w, with 2 per pots, but the glow is warm at least. The net size up being a tad to long to fit right.
    so i replaced the whole main floor, the halway lights flicker a tiny bit even when turned off. So power is getting to them, the halogen did not show this, so these are a lot more sensitive. Kniwing nothing about electricity, im thinking its related to the wall switch. Makes sense or is there something else i should look for?
    Yes, I would disconnect the wire from the switch and see if they go out.
    Very strange!
      A multimeter will show the amount of power at the socket with the switch off. I'd check that too. Good luck Cap'n Michel
