Looking at 99 47 Bayliner, Broker says it needs a port fuel tank replaced . Does anyone know anything about removal and installation. Much appreciated .
4788 FUEL TANK REPLACEMENT
Hmmm
This is the first 4788 I've heard of that needs a fuel tank replaced.
My initial thought is to cut it out the side, but that's just me.
Whats the weather like on the boat https://www.weatherlink.com/embeddab...59665f4e4/wide
Where am I right now? https://maps.findmespot.com/s/218P#history/assets -
1995 3270 - a model in which fuel tank replacement is very common - Previous owners replaced one tank, and had other cleaned & epoxy lined. Epoxy repair is wayyyy less disruptive.
I’d definitely consider epoxy
Where is the boat?1985 Bayliner 3270
110 Hino/Hurth 360A
previous = built own Roberts V495, circumnavigated
previous = Apollo 27
previous = Folkes 39, sailed to Hawaii
+ few more before that..Comment
Not sure where you are but petro-clean is my go to fuel tank issues. I would never trust a broker but get a good outside opinion first. Petro-clean out of Bellingham Wa. Said that the metal thickness on 4788 fuel tanks means they unlikely to need repair. Again ask the pros.Comment
I saw the Yacht yesterday and got a look at the tank and its location. There wasn't any fuel presently on the loose and did not smell of diesel in the bilge.
In order to remove and replace tank the kitchen needs to be removed and of course the floor. My thought is the tank needs to be pressure tested to really determine if she leaks ..
Visually the top is exposed and looks fine . Thanks again.Comment
Do you want to deal with a boat that the owner knows or thinks has problems, but is not doing anything proactive about them?
Where am I right now? https://maps.findmespot.com/s/218P#history/assetsComment
