Back on my little floating home
    Well... i am back on my little floating home after spending the last three weeks helping with the earthquake repair, which then became a major remodeling project around the house.
    Happy to escape the contractors!
    late fall is here in seward Alaska and except for the commercial fishermen, the docks are empty for the winter.
    Although I like the hustle and bustle of tourist and recreational boating season here in Alaska, it sure is nice just hanging out in the winter here.
    More outside photos in the morning once it’s light.
    Click image for larger version  Name:	B76E2C6D-353D-4A7E-AD2C-E6ECF2456571.jpeg Views:	0 Size:	239.1 KB ID:	545549Click image for larger version  Name:	F3903E08-86DF-4339-8031-1EFB17E9E73E.jpeg Views:	0 Size:	244.3 KB ID:	545550
    Gonna be down to about 4 hours of daylight soon though huh?
    SeniorEta 1993 Bayliner 2859 7.4L
      Little? Daylight? Alaska?
      1998 BL Ciera 2655 Sunbridge LX (Special Edition)
      "Sea Flights"
      5.7L 2bbl w/Thunderbolt Ignition and raw water cooling
      A​​​​​​lpha I Gen II Sterndrive/1.45:1 gears
      M15.25 X 15P Black Max prop
      MFG Extra's - A/C, Fresh Water Engine Flush port, HWH and Windlass
      Docks @ Punta Gorda, Florida
        At least you didn't go to any trouble cleaning up before taking the pics.
        "The Profit"
        Sunny Florida
        2019 Tahoe T16 75 hp
        2018 E16 75 hp......Sold
          Yes, the daylight is decreasing. In the dead of winter it gets light around 0900 and dark around 0400 pm
          Nope, didn’t clean up. The stuff on the bar is just as I left it
            This is what waking up in seward Alaska in late October is like.
            It’s about 40 degrees right now, and it will get up to probably close to 50 today.
ID:	545604Click image for larger version
ID:	545605Click image for larger version
              and then the day turns gorgeous
ID:	545639Click image for larger version
              • pgiconch
                pgiconch commented
                Very nice.
              Great shots, Kevin. You are a yachtsman. The correct placement for the US flag is never on the bow pulpit, though. Real boaters fly the ensign on the stern. From USPS:
              The U.S. national ensign, sometimes called "50-star" or "Old Glory," is the proper and preferred flag for all U.S. vessels. Your boat should wear it from 0800 until sunset, and when you enter or leave port during daylight or at night, weather and rig permitting. While in port, if you leave your boat and will not return before sunset, lower and stow the national ensign before you go.
              The national ensign worn by a vessel must be the flag of her registry—not necessarily that of the owner or operator.
              Generally, the national ensign should be displayed at the peak of the gaff, i.e., the outer end of the spar extending aft from the mast of your boat—if you boat has a gaff. If it does not, fly it from the flagstaff at your boat's stern. If your boat has an overhanging boom or an outboard motor, your flagstaff may be offset to starboard (preferably) from your boat's centerline.
              On a sportfishing boat, where a stern staff might interfere with the gear, and vice versa, the practice is to fly the ensign from a halyard rigged amidships on the after part of the superstructure.
              Marconi-rigged sailboats may fly the ensign from the leech of the aftermost sail (or from the back stay), approximately 2/3 the distance up its length. This puts it in about the same position it would occupy if the boat were gaff-rigged.
              At anchor or made fast, the ensign should be flown from the stern staff of all boats. The U.S. national ensign has a 10:19 hoist/fly ratio.
              Tally and Vicki
              "Wickus" Meridian 341
              MMSI 338014939
                Apparently Im not flying my flag correctly either😳
                I say fly your flag wherever you’d like.
                I’m a bad boater, bad boater I say😆
                "THE FIX"
                Misc. projects thread
                  Hmmm.
                  That is GREAT information. I’ll have to think about moving the flag.
                    I fly both a stern and pulpit US flag and guiltily, I normally do not lower them at night. I’m also a bad boy! 😁
                    PS Great shots of beautiful Ak! Personally, I’m just not ready for 30-40* temps and 6 hrs of low hanging sun. It was 90* here in LA the past few days and plenty of sun! Of course I didn’t mention the Santa Ana winds were bowing, there were multiple brush fires, the traffic was horrible and the homeless population is at an all time high! Give and take.
                    Jim Gandee
                    1989 3888
                    Hino 175's
                    Fire Escape
                    [email protected]
