Storage on board...
    Storage on board...
    Any creative storage ideas or concepts out there among the members? At only 39' long Sedan, I am trying to identify some places and methods for storing different items.
    John
    1986 Marinette 39 Sedan after enjoying our 1984 Marinette 28
    (formerly 89 2755 5.8 OMC & 97 1850SS 4.3L Alpha I)
    If there is a panel, try removing it to see what's back there. Aboard a nearby boat, under the side decks, accessible from inside are storage spots approximately 1' deep and 10" high.
    Aboard Seaweed, under the old reefer was a closed cabinet about 8" tall and 24" x 24". It took a while to saw through 30 year old solid teak 1" thick, but I did it. My pressure cooker, along with other goods fits down there. It's not the Easiest to access, but it is a dang sight easier than going in from the locker next to it.
    I took one space that was 24" square and added cleats/made shelves.
    I added a shelf for my tin foil in that small area adjacent to the sink. Under the shelf, I rigged up a paper towel holder. That sounds fancier than it is. Actually, it's a small piece of teak with a couple of pieces of "small stuff" to hold the roll to the shelf bottom.
    Under my bunk was a cavern, with the bottom the bilge. That wouldn't be good for storage, so I added aluminum angle iron and created my own shelf down there. The panels come up (access to water tank, thru-hulls, etc.
    In my forward cabin, above my bunk is a unit for my DVDs.
    You might notice under and to the far right is a small VHF radio. I added that shelf too.
    The DVD rack was built by a friend on a Bristol 24 about 10 years ago. I still use it.
    The hidden spots (check for access, and if there isn't make some)
    Seriously, a lot is there if you're determined to find it. Being able to get into the lockers is important too. Don't overlook that.
    For instance, in my galley I have two bench seats. Access is from above. Well, that's a pain in the transom. Move pillows, cushions, etc. So, another pal made access along the passageway. I have used those two lockers almost every day of the past few years.
    Ditto the one under my bunk. Remember the shelf I built? Well, here's how I get to my stuff:
    None of this is Perfect. All of it works though.
    Good luck and have fun.
      Good ones. Thank you Janice.
      John
        Nothing as Fancy as Janice...
        I use stackable tubs, and use the spare stateroom that is now a storage closet.
