PROPS: 24" Nakashima High Skew 4 Blade NiBral Propeller 2" SHAFT *Nakashima *designed for Bayliner, Meridian and Sea Ray Motor Yachts
    $2,200 for the PAIR. ....They sell for $2,200 or more EACH. 24x24
    Nakashima Propellers, Japan designed for Bayliner, Meridian and Sea Ray Motor Yachts
    We sold our Meridian 408 and had these extra pair of props but the new owner did not want them - We took them to Kruger & Son, Ballard, Seattle to be polished and balanced and whatever else they do. They gave us the print out from the computer balancing/pitch. I can email this to anyone that would like the reports. They are beautiful! Should be a piece of art.
    You pick up please. We are 20 minutes from the Kingston Ferry (out of Edmonds, WA) in Hansville, WA
    THIS IS FROM THE NAKASHIMA SITE.
    Nakashima Propellers designed for Bayliner, Meridian and Sea Ray Motor Yachts
    Propellers with a sharp sweepback blades are often called “high skew” propellers. The unique shape of these Nakashima Propellers reduces the vibration of a vessel's body as well as propeller noise. Nakashima provides high-performance and high-quality marine propellers by optimally balancing propulsion efficiency, strength and vibration performance according to each customer’s special requirements. We have sold thousands of NAK Propellers worldwide for all types of vessels from heavy commercial to high speed luxury Yachts. Nakashima Propellers Highly Skewed blade design eliminates noise & cavitation and is most desirable for medium to high speed in tunnel operation.
    Propeller Specifications: SAE Standard Taper & Keyway.
    • Factory Bore : 2"
    • Full Taper Hub Length : 6"
    • Pitch : 24
    • DAR : 0.75
    What pitch are they (re-pitching costs 1/4 of your asking price)?
    2000 Bayliner 4788 "Perfect Balance"
    370HP Cummins
    Zodiac YL 340 30HP Nissan
    Moored at Roche Harbor
      they are 24. have the computer data sheets from Kruger
      they have been taken to Kruger & Son in Seattle...Ballard.and put on consignment as I did not have room for storage.
        Hi, I am interested. I have an 04 Meridian 490. I just need to double check to make sure they are correct for my boat.
        David
          Davido, these are top notch props, if you plan on any long range cruise having a second set is a good idea. however I suggest you read up on the threads regarding repitch of the 490/4788 props. They came from the factory as 24x24, however at a 24 pitch they put a lot of strain on the engine and may cause a much shorter tIme between rebuild of your engines (engines can be over $15k each). I had mine pitched back to 22inch, some owners have gone down to 21. Huge difference in performance and you can tell the engines are less strained.
          4788 PH 2001, Cummins 370's
          MMSI: 338013392
          Call sign: Sea Daze
          Exploring the Salish Sea
            Still available?
