i have a merc cruser 5.7 tryed my hand at installing a new pump on drive everything looked good till i tryed to pump in drive oil. wont come out top port seeps out small holes by fins, any suggestions would be helpful thank you pat newbie.
problem-gctid358370
Sounds like you didn't replace or get in the right place some orings that go between the two halves.
You might het a better response id you put more of the question or a topic in the title.
1989 Avanti 3450 Sunbridge
twin 454's
MV Mar-Y-Sol
Twin chevy 350's inboard
Ben- Jamin
spokane Washington
Hi, Pat,
To add to David's post- please give as much information as you can about what you're working on- things like:- vessel make and year
- drive type
- engine data
Help us to help you.
A title like "problem" is rather vague.
If this is an A drive, I'll agree with Dave.
There will be an O-ring seal that installs in a small groove in the oil passage that leads from the lower unit to the upper unit.
When this area leaks, you may see oil where you are describing it.
Rick E. Gresham, Oregon
2850Bounty wrote:
+ 1
twin 454's
MV Mar-Y-Sol
Ben- Jamin
spokane Washington
And it really is not an "O" ring per say - it is a flat rubber washer about 1/8" thick that fits into the flat machined "groove" of the lower unit.
