I'm going to install a new lower shift cable on my cobra drive while I'm replacing a tilt pressure line. Does the shift cable alignment tool save enough time to be worthwhile? I know you can do it without it. I'm just trying to justify the cost vs. time.
The tool is available for $75 made by GLM. Also is an aftermarket cable ok or is OEM the way to go on this part?
Thanks,
Greg
Thanks,
Greg
