Looking for best and easiest location for the charger, boat doesn't have one now. Pics if you have them. 3 Bank system. Thanks, Dave
(39)94 2452 Battery Charger-gctid358066
I had installed a Guest waterproof charger (2 banks, 20 amps) on my 2452 right above the batteries in the port side lazarette. My kicker bracket mounting plate is just above the scuppers, so the 6 bolts were protruding about 1.5" through the transom and backing plate into the lazarette space. I had mounted two aluminum channels to these bolts, drilled the holes for the charger, and mounted it to the channels. Works great, it is close to the batteries, and I can see the led lights on the charger when I open the lazarette.
Alex
1997 2859, 7.4 MPI, Bravo II
You really need a only a single dedicated cranking battery (#1 MBSS position) and a HLBB (#2 MBSS position).
Just curious.
dmax2 wrote:
How did or where did you run the power to the charger?
Take the charge leads to the rear #1 and #2 terminals of your MBSS, also making these permanent connections, avoiding the Rat's Nest and small terminal corrosion potential at your batteries.
Take the charger Negative lead to a system negative engine connection.
This not only avoids the Rat's Nest, but without these making direct battery connections, R&R'ing batteries will pose less confusion as to what's this/where does this go?
Rick E. Gresham, Oregon
on my 93 it is installed under the port cockpit seat, the same side has the shore power plug, just under the port cockpit/hardtop window, makes a run to the breaker panel in the cabin then back to the charger
3 bank because, 1 start and 2 house batteries. Boat does not have factory fuse box. If it doesn't work out I'll stick with just 2. I know what your saying on rat's nest but the house are not in the same compartment as start battery. Do have shore power but only a dealer set up. At least this gives me some good ideas. Won't be able to get to the boat for another 1month or so. Will entertain all suggestions, keep them coming. Thanks, to everyone. Dave
1994 2452
5.7L Alpha Gen. II
"HOOK EM"
:Sterling Heights, MI
MMSI#338128565
When you divide these, you'll very likely find yourself drawing them each down below 50% much sooner than if it were one large bank.
By increasing the depth of each cycle, you will inadvertently shorten their life span.
A good 2 bank O/B smart charger will do you just fine.
You may even find that the savings from the 3 bank to a 2 bank, will allow for a higher amp 2 bank charger.
Just say'n!
Your call!
dmax2 wrote:
Thanks fishaman, How did or where did you run the power to the charger?
Alex
Just wire your 2 house batteries in parallel and bingo... 1 big house battery. Then wire your switch and charger for the 2 banks. No need to separate the house batteries...
Dave, one of us can explain the Amp Hour capacity issue (2 separate banks -vs- 1 large bank) if need be.
But both you and you House Bank will be much happier if you group the two together (making one larger bank), and then use a 2 bank charger.
Just talked to a fellow who distributes batteries in my area. He said do a large house or parrallel 2. You are right Rick to use a 2 bank charger. Taking 3 bank back today and going with a 20 amp 10/10 2 stage. Thanks,Dave
1994 2452
5.7L Alpha Gen. II
"HOOK EM"
MMSI#338128565
