Hello all would like to known about mounting a naxa 19inch tv/dvd combo to the side wall of the head i have a 1994 2355ceria the tv/dvd is AC/DC wei no more then 10 lbs 32watts 4 amps my engine is a 4.3lx v6 i should be able to just plug into the crigtt lighter ? and what would be the best tv mount ?
tv mount-gctid357384
ratedrg wrote:
looking for a answer
You can search some threads on mounting TV's
Lots here have done it.
Welcome to BOC.
I looked at the 19" Naxa on their website. It says it is wall mountable. It does not include the bracket or list the required bracket.
Generically most of these new flat screen TVs use a VESA mount. Do a search for VESA Mount to see options.
Mounting the bracket to the wall use Stainless Steel thru bolts, washers and nylock nuts. Screws will not remain secure on a bouncing boat with the weight of the TV.
Jim McNeely
Twin 5.7s with Bravo2 drives
Brighton, Michigan USA
MMSI # 367393410
then I used http://"http://www.amazon.com/gp/pro...Monitor TV 1E9
The TV and DVD works great and plugging into cig lighter outlet should be fine. You do need a decent antenna.
Antenna article:
http://baylinerownersclub.org/forum/...ad.php?t=63682
The 12 V outlet should run it fine.
Captharv 2001 2452
Anyway I have this one, which we really like because it can swing to face any direction. I got an extra slide-on wall bracket so we can move it from cabin to cockpit in seconds with no tools.
http://www.amazon.com/Level-Mount-EL...m/B000A0HF6M/2
SwampNut wrote:
Seriously? Four hours and you've already added two whining posts on top of your question? Little impatient and rude, don't you think?
Simo
2002 2855 350MPI Bravo III on Lake Champlain -> SOLD!
Downsized to a couple of kayaks for now.
http://www.baylinerownersclub.org/fo...on-245-Cruiser
CE
