Hello all, pulled my boat out early last season as I assumed I had spun my prop, reving out at any increase in throttle, like a clutch slipping. Now that I have removed the prop it looks indentical to the new one with no sign of slippage on the nylon insert. When I fit the new Mercury prop which has the same serial number it seems to fit on the shaft a fraction too much towards the drive which results in it rubbing off the housing of the drive beyond the thrust washer.
Any ideas guys, has my prop been spun and if not what caused this "slipping clutch " type of event.
