aq 225 oil pressure-gctid470415
    Hi does anyone know what the oil pressure should be on my aq225 its running at about 60 psi is that right ?
    Cheers paul
    60 psi would be about right when cold. When warm, I think you'll be looking at the 45-ish psi range.
    If you are seeing 60 psi when warm, your sender or gauge may be faulty.
    The SBC oil pump is capable of up to 200 or 300+ psi, but the relief valve is what controls the pressure that the engine oiling system sees.
    Rick E. Gresham, Oregon
      Thanks for your reply
      Paul
