Cabin Light(s) Power - 1988 2455 Ciera-gctid469912
    Does anyone know where the power is fed from for the 12vdc cabin lights? Sometimes they work, sometimes they don't. I read voltage at my fuse panel and all fuses check out ok.
    Any help is greatly appreciated.
    Most likely a bad ground, check & clean the conection on the ground buss. Good luck
    Capt. Ron.
    "Never Trade Luck For Skill"
    Hino EH700
    Westerbeke 8.0
      Thank you. Cleaned up the ground buss and the rest while I was there. Working much better!
      On another note, does anyone know the bulb number for the star wars instruments? All work but my temp gauge.
        anyone????
