my volt meter gauge on starboard side both upper and lower helm sticks at 12 volt with out the key in Ignition. When I crank the engine the meter jumps to 14 volts when I shut down the meter goes back to 12 volts instead of shutting off.. does anyone have any idea as to what is causing this at both helms? could it be the ignition key set is faulty on one of the helms? I would appreciate any and all advice..
Bryan
Bryan
