Starter corrosion question-gctid465420
    I went out the other day to take my cover off and let the inside of my boat ('87 1950 cuddy with a 3.0) air out a little bit. what I saw was very aggravating. I apparently made the classic mistake of leaving my drain plug in the boat so my engine compartment and half my carpet were both under water. :banghead I drained all the water out, let it dry for a day or two, and returned today to change my old plugs, engine oil/filter, lowere unit gear lube, etc. One of the wires on my starter was literally totally corroded in two. I realized this after none of my gauges would work and the engine would not fire. after jiggling the two wire ends to get them to touch, all my gauges would work but the engine wouldn't crank...it just wants to click once when I try to start it. I have the boat battery hooked up to my truck battery so I know it's not low on juice. Could the starter no have enough power to start the engine bc there is barely any of the wire actually connected? again, it will run my blower, bilge, fish finder, stereo , etc. but it will not fire the engine. I know I need a new wire since it's cut into two pieces but could that be effecting the engine starting? It would be like jumping your car with a jumper cable that is cut in half and barely touching the other part.
    Once a starter motor has been submerged, it becomes highly unlikely that it will work again. And if it does work a day or two after, it most likely will not a week or two from now.
    Replace it, and replace it with a HTGR/PMGR unit, and don't look back.
    Rick E. Gresham, Oregon
      Replace the starter as Rick says and also replace the wire. You might make contact to get the gauges working but not good enough to engage the starter.
      Doug
        Was this a salt water issue?
          They don't even do that well after being submerged in fresh water.
          2007 Discovery 246
          300mpi BIII
          Welcome island Lake Superior
            Pat, I wondered that also. Possibly a bit of both.
            Perhaps salt water re; the cable end issue, but even plain ole rain water will crust over the commutator on the motor's armature.
              I have rinsed/soaked salt water electrical items in fresh water and they survived, I do not recommend it for a starter though, I would give the cables chance, keeping an eye on the cable to terminal for corrosion if soaked in fresh water. Starters and alternators are cheap, check D&B electrical, they are not worth rebuilding in most cases.
                No need to replace just take it in and have it rebuilt. Cost about $80 for a starter rebuild for us in Seattle
                  Yes, however, his 1987 OEM starter motor will be a non-gear reduction motor..... probably similar to this Delco.
                  None of the Marine Engine suppliers are using Non-Reduction motors these days. Most everyone is using the higher armature speed HTGR/PMGR motors.
                  These armatures spin approx 3 X's faster than the older style, and with the gear reduction, these give the engine faster cranking RPM.
                  For that same $80, or close to it, he can buy one of these.
                    You will have to make a bracket to the block if you buy a new style starter.
                    I do recommend what Rick said dbelectrical.com will have it the least expensive on the net.
                      Also, pay close attention to the altenator. It may need replacment as well. I had a raw water coolant line break and had much the same experience. In 2 weeks they both required replacment/rebuild.
                      Chay
                        Thanks everybody. Yes, it was just fresh water (rain water) but it was probably submerged for quite some time. I looked on ebay and brand new starters are $60-$80. I'll start from there and see what I come up with. I just hope I get everything wired the right way...
