V/P 280 DRIVE ON A 5.7 LITRE AQ260A drain plug seal??-gctid354347
    While changing the the oil in the drive i noticed the gasket around the drain plug is a flat fibre type washer, I ordered new seals from doug russell marine and they are a oring type seal, the same seal fits the drain plug and the quick fill bolt on the top of the transmission acording to the parts schematic and doug russell, Would the fibre type wahser be something someone used inn place of the oring, your thoughts please
    Thanks in Advance
    Dan
    The fiber washers were used on the early AQ series drives.
    Your 280 requires the O-ring at both the drain plug and the dip stick (same p/n).
    Not sure what you are calling the "quick fill" bolt! Are you talking about the "hollow" bolt?
    The hollow bolt O-ring is unique to that bolt shoulder. Do not substitute!
    The 280 fill port is at the 1:00/2:00 O'clock position just above the shift mechanism.
    If your drive is a 280 or later, it will have this fill port.
    This plug requires a red phenolic gasket.... not an O-ring.
    Be sure to install the drain plug with a hand held impact tool.
    Just several mild blows will set the tightness.
    Hand tight, and you risk this coming loose, IMO.
      Was not aware of this fill port above the shift mechanisim, Is that in behind the shift cover?? always filled through the hollow bolt and this is the seal mean , It is the same as the drain plug
      Although i have had the shift cover off i have never seen this plug?? perhaps i dont have a 280
        Bounty you absolutley right ( as always ) The drain plug and dip stick are the same seal the hollow bolt is different, Now to find that quick fill pug ?????
          1.... Is that in behind the shift cover??
          2.... always filled through the hollow bolt and this is the seal mean , It is the same as the drain plug
          3... Although i have had the shift cover off i have never seen this plug?? perhaps i dont have a 280
          1.... No....... this would be forward of the shift cover. https://"http://www.marinepartseurop... 5 and 6 here.
          2.... Sorry...... not following you on this one.
          3... Any drive earlier than the 280 will not have this.
            Bounty , always filled through SEQ#8 and 9 hollow bolt on top of the transmission,was not aware of the fill option as you described, Am i correct in saying the drain bolt and dip stick are the same seal??? But the hollow bolt is different??
              Correct!
                Thank you so much for that info, As always you guys are fantastic!!!!
                Dan
