Hi,All this talk about SmartPlug has me excited. It was a real PITA to lean over the boat to unscrew two shore power (Y adapter) cords and a "F" connector for cable TV port side.I always back the boat in my slip so started thinking why not add a second shore power location (with SmartPlug of course) at the rear of the boat with "F" connector. (see picture)Ideally I'd like to run this in parallel so if I'm at another marina nose in I could use the existing old port side location INSTEAD (never two locations at the same time). I'd run 10 gauge 3 conducter and connect to the existing shore power connections port side.Would this work? Any pitfalls? Has anyone done this? Does the gauge need to be bigger since it's further away from the main breakers?It would speed things up a lot for me and make it safer! I could avod the port side all together and make them fake ones but if I could get them even better.Please comment.Thanks,Steve
[img]/media/kunena/attachments/vb/656618=24892-157_rev.jpg[/img]
