Monkey Fir Cleaning-gctid353496
    Quick and easy way to clean the monkey fir, Just did the hard top underside of my 2452, used my pressure washer, turned down the pressure, used a wide angle tip then went over it with a shop vac, AMAZING, It looks like brand new again, plan on doing the V berth & walls this weekend, just need to stay on top of the vacuuming, going to put a radiant heater & fan open the windows for circulation, Just a little FYI,
    I like to use oxi-clean on the monkey fir. It will get rid of the stains and that dull color from cooking in the boat.....
      There is a guy who comes to the marina every spring, and charges me 80 bucks to clean the entire boat. He has a steam cleaner inside of a van and 200' of hose and does all the monkey fur, carpets, and cushions. I figure I cannot be doing to bad for 80 bucks for the whole boat. It is cleaned , deodorized, and sanitized. I actually never even though of doing it myself with such a cheap option available.
