Furuno sounderto raytheon cable-gctid353472
    Guys I have an old CRT Furuno that I am trying to wire up to a rayTHEON 7 pin ducer (with a foil shield) .
    There are a white a black and a braided (ground??) coming out of the furuno. I am getting a good picture but wave-patterns (like moire) on the screen and it loses bottom over 60 ft. Using butt connectors and going ground to raytheon shield (no other option I can see) Anyone out there got a direction you can point me in to make this connection a little better?
    Try the Airmar site: http://www.airmartechnology.com/2009...ch.asp?Type=FF
    Or try GEMECO, Wholesale only, but often very helpfull. http://www.google.com/url?sa=t&rct=j...OTFERZkb3O-HPA
    Pat says: DO-IT-RIGHT THE FIRST TIME!
    Bayliner 3870 "ALASKA33)
    Twin 350 GM power
    Located in Seward, AK
    Retired marine surveyor
      Theres more to it than wiring it. Are the frequencies the same in both units?
      Is the power output of the two simular? Are both outputs balanced to ground or coaxial?
      Its not as easy as just wiring it to a plug.
      Captharv 2001 2452
      "When the draft of your boat exceeds the depth of water, you are aground"
        Power similar, frequencies same. I think it is the difference in shield vs ground. How to work around it? Hmmm
          Some transducers excite differently and are just not compatible with certain sounders.
          Arimar.com has a good cross reference.
          As was posted above, some use a signal to ground, some use a differential signal, some use separate elements for the 200 and the 50 KHZ frequencies.
          Some older units even use different frequencies.
          KEVIN SANDERS
          4788 DOS PECES - SEWARD ALASKA
          Whats the weather like on the boat
          https://www.weatherlink.com/embeddab...59665f4e4/wide
          Where am I right now? https://maps.findmespot.com/s/2R02
