Stuck Tach
  • Stuck Tach
    After a 90 mile run yesterday my final engine start to blow out the exhaust after flushing resulted in this, see pic..
    ( no I didn't rev it that high)
    Click image for larger version  Name:	20230918_090851.jpg Views:	0 Size:	1.54 MB ID:	676565
    The usual amount of slapping did not return it to zero, but one wave of this magic wand did it,. see pic....
    Click image for larger version  Name:	20230918_095330.jpg Views:	0 Size:	1.74 MB ID:	676566
    It is a magnet that is used in a partical filter on the ultrasonic tank at work, it is in the pump out / drain circuit.
    I don't know what type it is but it ridiculously strong !
    To show how strong it is, I can move my mig / tig combo with tanks on it just by having it stuck to the sheet metal. see pic ...
    Click image for larger version  Name:	20230918_095402.jpg Views:	0 Size:	1.82 MB ID:	676567
    The lesson learned here is when slapping doesn't work, use a magnet to move the needle back to zero.
    " WET EVER "
    mmsi 338108404
    mmsi 338124956
    Did you blow up your engine? Your first sentence is hard to understand.
    Using a magnet to move a needle back is something I've never heard of. Hope your gauge will work next time. I have no idea how a rpm gauge works, most other instruments use a bridge setup between the coils where 2 try to balance to neutral (=0) and the third cauaes the deflection. That caused my oil pressure gauge to spike to 80 psi with engine not running.
    1989 2159 Trophy Hardtop
    5.8L OMC Cobra
    2 1/2 year restoration project after "all you need to do is put the rebuilt engine back in".
    Mountlake Terrace, WA
      Did not blow up the engine, tach works normal.
      " WET EVER "
      mmsi 338108404
      mmsi 338124956
        Great! Your magnet fixed it then.
        5.8L OMC Cobra
          Dean, I had a similar issue years ago when the ignition switch got bumped to the off position while running at 3600 rpm. Tach was stuck at 3600, when I restarted the engine tach was still stuck but after giving some throttle it started working as expected and haven’t had any issues since.
          Weird stuff…
            When mine goes wank it happens when starting, the needle will swing wild to a high point and stick, a quick backhand or two snaps it back to reality.
            Not this time.
            I was about to remove it, that's when I had the magnet epiphany.
            " WET EVER "
            mmsi 338108404
            mmsi 338124956
