Hello everyone. I am brand new here, so I apologize if this is in the wrong place.
TO BEGIN: This is my father-in-law's boat and I'm unsure of the exact year. I know it is a Volvo Penta AQ131a. I will also disclose that I am not well versed in the marine industry, however, I turn wrenches on cars/truck/bikes quite often.
Last summer, I was recruited to get this boat running. The owner had put a new "flamethrower" ignition coil, a petronix 2842, new spark plugs, new wires, everything and it still would not run. NOTE: he ran a jumper wire to the coil to provide the petronix with the necessary 12 volts (eliminating the resistance wire). When I began working on it, I discovered that the countershaft timing could be causing the issue.
Low and behold, the countershaft timing was incorrect. We bought a new timing belt and installed it according to the manufactures guide. After reassembling, we got the boat to run, but it was at the end of boating season.
The other day, we went to get the boat running again and it will NOT start. The spark seems to be weak. We also can barely get the engine to even fire on any of the cylinders (like there is no spark). We just put a brand-new battery in it, check the distributor ground, and seem to have checked everything and CANNOT GET IT. The ONLY way it will even act like it wants to start is when the distributor is maxed out, clock-wise rotation. Any insight is appreciated, thank you.
