I used the search function already, but here goes.
I am helping a friend fix his Bayliner. I believe it must be around 2003, as I saw a sales video of a 2003 which looks exactly the same, and with the same gear/throttle shifter.
It became very stiff, almost impossible to shift. I took the handle apart and found the cable from the release switch has no movement when pulling it manually. It is possible to force the throttle into forward gear, but it isn't right. Obviously, the latch doesn't release.
I am trying to remove the entire unit from the side wall. There are 3 7/16" head bolts which I could remove, but the three 3/8" head bolts just keep rotating. I can stick a hand in behind the side wall and just touch one of them. I can feel the bolt, and the nut rotating.
I don't have a repair manual, is there a trick how to unlock it? The handle is partly loose, now that I got the 3 7/16" head bolts out. Does the handle have a hidden hex screw to make it come loose?
Also, most of the gauges do not work. In particular, the fuel gauge is not moving, is there a typical fault here or does the tank sensor needs changing?
The photo shows how far I managed to get. I need to get in to where the throttle lock is located.
Thank you for your help
Core
Core
