Fluxgate Compass Replacement
    The nav electronics on board are probably old enough to drink at this point but still functional for the type of boating that I do. ( for now)
    GPS, Radar and Autopilot were all taking heading data from a KVH 1000 fluxgate compass.
    This device has died- there is salt corrosion on the board that is terminal.
    Looking at a replacement KVH, new ones are going for $8-900 if you can find one and used on E-Bay is still +/- $400 and then taking chances with used gear.
    I have found a fluxgate heading sensor- Digital Yacht Hsc100 High Performance Fluxgate Sensor- https://www.hodgesmarine.com/dgyzdig...xoCIxkQAvD_BwE
    That seems to fit the bill and it is a new ( ie- not used ) device- it has standard NMEA 0183 HDG, HDM, HDT and HCC output. My GPS- Garmin GPSMAp 3010C appears to be looking for the same sentences. There is no backbone or networking on this gear, the devices are hardwired to each other- not pretty under the dask but was functional until recently.
    Since I do not need the the visual compass readout- does anyone have any words of caution against going this route?
    or
    Always glad to take an alternative approach.
    A new suite of electronics is in the plan, but not this year.
    1992 3888
    W04C-TI 210 Hinos
    Westerbeke 8 KW Genset
    NMEA 0183 sentence is a sentence regardless of what originated it. Your devices won't know what sent them. Should work.
    Tony Bacon,
    Washougal, WA
    Caspian, MMSI 338355743
    1997 3788 Cummins 250hp
      Thanks for the validation. Uncharted territory for me.
      1992 3888
      W04C-TI 210 Hinos
