Good morning,
As many of you may remember I've upgraded my old 350 to a new Votec 383 with a Penta duel prop. All is going well and I'm in the final stages. The last item I'm working on his running the raw water lines to the crank mounted Johnson F5B pump as recommended by someone on here. It looks as though the transom intake tube is 1 1/4 inch, the pump is set up to receive that same size, or i can thread in a barb. The hose connection on the engine and power steering cooler are 3/4.The problem is that those threads on the pump are a British thread pattern. (of course)
I guess my question is should I just find a 3/4 barb with those threads for the pump both inflow & out outflow, or should i keep the 1 1/4 inflow and use a 3/4 outflow?
Hope this makes sense. simple things are the biggest pain.
