I have attached the pictures of my thru hull scupper and the tapered cone seacock. I am at a loss to figure out how to remove the seacock. There does not seem to be any bolts coming up thru the hull to hold it on. I know that it threads onto the thru hull, but I did not want to just start cranking on it and do more damage. It does work, but the outside tightening nut broke off. it is on a 1982 3270. Thanks in advance for any help!
Removing SeaCock
The way you remove that is you do it from the inside.
Remove the screws that keep the valve from turning first.
Then unscrew the valve assembly. What you will have leftover is a threaded throughhull inside the boat.
That can either be removed or reused.
Whats the weather like on the boat https://www.weatherlink.com/embeddab...59665f4e4/wide
- Likes 1
Originally posted by Frogman View PostI did not see any screws other than the one that the ground wire is on. There were some on the scrupper, but they did not appear to go all the way through!
Remember these are straight threads so the threads do not keep the seacock from turning much.
If memory serves correctly you might, might even have a nut under the seacock that fastenens the throughhull to the hull, but I do not remember.
- Likes 1
Originally posted by Frogman View PostOk, thanks! I will see what happens...lol
Your seacock valve and flange appear to be all one piece so likely no additional screws.
I did see those. I was not sure if they were there just to keep it from turning when the seacock was screwed on. I am always reluctant to start taking things apart for fear of making it worse...especially below the water line. But I guess that is the only way to find out. Thanks for your input.
I was unable to remove those screws. Did not want to strip them out. I was able to get it to turn from inside the boat after squirting some kroil oil from inside and under the boat. Not sure if that did the trick, but when it finally moved, I was shocked....lol
- Likes 1
