1997 Ciera 2655 Merc 5.7L Alpha1 Gen2…Boat sat for over 10 years
Ok, so I can turn engine by hand (Marvel Mystery Oil in cylinders, soak for days, plugs removed, then attached tool to balancer and with ½ in breaker bar engine now turns).
I replaced the starter “relay”… the starter still didn’t crank when I turned ignition key.
I attached a remote starter button (one lead to positive post on battery, the other lead to the small post of the starter solenoid (a yellow and red wire was attached there)….pressed the button and nothing. I verified with multimeter that the remote starter lead at the solenoid had 12+ volts.
My research implies the starter is bad and should be replaced/rebuilt based on the above (I don’t want to mis-diagnose so I’m posting the question. Based on the test setup do you believe the starter is bad or do I have to keep digging?).
Did I miss something? Was the remote starter properly attached? My question is: can a starter go bad from sitting for so long, or is it more likely to have been damaged when I attempted to start a seized engine?
No prob if the starter has to be replaced, I want to make sure before proceeding.
Thanks,
Don
Thanks,
Don
