I recently purchased a 1984 Ciera and it has two batteries. Currently, there is a multi battery isolator & and solid state dual battery protector installed. I believe the purpose of the isolator is to prevent the batteries from draining into one another and the solid state protector assists with cranking amps for starting the engine, in addition, to offsetting amp loss due to the isolator.
I want to know if it's safe to install a 2 bank battery charger to the batteries along with the isolator and protector or should those pieces of equipment be completely removed?
