Bayliner 3988 Window pulls
    Hello,
    Does anyone know where can I find replacement sliding window pulls for 1999 Bayliner 3988.? They are black plastic, about 1.75” diameter, held in place by a brass screw that goes through a hole in the sliding glass window panel.
    2006 Bayliner 285 Ciera
    Engine: Mercruiser 350 MAG MPI Horizon (300hp)
    Outdrive: Mercruiser Bravo III
    Length: 29′ 6″
    Beam: 9′ 10″
    Draft: 3′ 1″
    Weight: 7185 lbs
    Fuel tank size: 102 gallons
    Water tank size: 33 gals
    Garmin radar
    Garmin GPS/Sonar
    You may not find an exact match but mcmaster has a ton of knobs to choose from. Grainger to a lesser extent.
    Nobody gets out alive.
      KWB:
      Thanks for your help - looks like McMaster-Carr has a similar knob.
      Length: 29′ 6″
      Beam: 9′ 10″
      Draft: 3′ 1″
      Weight: 7185 lbs
      Garmin radar
      Garmin GPS/Sonar
        There was a thread about it recently, use the search function.
        1989 2159 Trophy Hardtop
        5.8L OMC Cobra
        2 1/2 year restoration project after "all you need to do is put the rebuilt engine back in".
        Mountlake Terrace, WA
          Yes, search window pulls, and you should find another thread with info on who has them.
          Tony Bacon,
          Washougal, WA
          Caspian, MMSI 338355743
          1997 3788 Cummins 250hp
            I used the McMaster knobs. I also used a rubber grommet in the window glass hole to get a good sealing fit. I have replace grommets every three to four years as the eventuality crack. Recall knobs from McMasters as well as grommets. Got the SS screws locally.
            1990 4588
            Port Hueneme Ca
              howsweetitis posted about this topic a while back. He had a friend with a 3d scanner and printer, took one of his pulls to him and got a few made. He provided the 3d model to me and I also printed some. I added threaded brass inserts for the screws. They're an exact match other than the finish is not 100% smooth although you would have to compare side by side to detect this. I'll ship to you for a nominal fee, made 9 spares. This is the other post: https://www.baylinerownersclub.org/f...dels-and-years
              Tony Bacon,
              Washougal, WA
                Tony Bacon:
                Thanks for the information, and my buddy who owns a Bayliner 3988 wants to buy some of your window pulls that you mentioned you had fabricated. How do we reach you? I'm not sure it's OK to post his email here. Pls let me know procedure and I'll put you two in contact.
                Thanks,
                Dave (Geekhead)
                Length: 29′ 6″
                Beam: 9′ 10″
                Draft: 3′ 1″
                Weight: 7185 lbs
                Garmin radar
                Garmin GPS/Sonar
