Wondering if I may have had something freeze in the fresh water pump or system this Winter ? The tank is full and the pump runs but doesn't pick up water. It just builds air pressure in the system. Any advise from the community?
Drinking Water pump just creates air pressure in system
As said above, either the filter is loose, "O" ring is bad, or bowl is cracked. The O ring is the easy and cheap part to change first. Note: use some "restaurant" grade silicon grease to lube the o ring. Seals better, and the plastic bowl does not survive the gorilla grip. Check to see if any of the Whale hoses and their fittings (blue and red) are loose. They developed a groove and leaked air in. I trimmed off an inch and re-inserted it. No more leaksCaptharv 2001 2452
