we just replaced the manifolds and Risers/Elbows on our '91 Capri 2050, Mercruiser 4.3 / V6 Alpha one. well apparently I didn't get the correct fitting or whatever it is... I found this video showing the part and correctly installed. but I can't find the proper name for it so that I might order the part so we can finish the engine portion of our project! if anyone knows what the fitting circled in red is on this screenshot I would be eternally grateful!! it's the piece that attaches the hose to the back of the Elbow / Riser thing.
need help finding the correct name for a part
Go to this site and enter your serial number of the engine to look it up.
https://www.mercruiserparts.com/part...ndrive-inboard
Threaded hose barb. That one looks to have a bit of an angle built in.Dave
Fwiw, I picked a 4.3 file that would have been built in ‘91. It may not be the exact one, but it’s close enough to help you know what you are looking for. With Mercury Marine serial numbers are the key to everything. Changes are made in the middle of production years, so the model year has less definition than the serial number. So, check the serial number range at the top of the page after you see how each part number is identified. For the example, it part number 12 on the diagram. Then going to the list of parts, number 12 is a 22-865159 Fitting, 45 degree the magnifying glass means there’s a note, in this case it’s because it’s a new part number superseding a discontinued design. Iiwm, I’d do a search on both part numbers looking for the best price to me. That means the total cost including shipping and sales tax. Oftentimes there are other parts I need or am going to need that if I combine with this part, I can get free shipping.
If I’ve oversimplified this, please forgive me. I want you to get the right “fitting or whatever it is…”
peteP/C Pete
FYI….., on the diagrams, the one, two and three digit numbers are the SEQ (sequence) numbers.
As Pete said, these numbers reference the actual OEM part number.
.Rick E. (aka RicardoMarine) Gresham, Oregon
