Kohler gen is not happy with something and probably when the sensors circuit in play shuts down it. The sensors behind and hard to access to check. Anybody familiar with the scenario?
Generator shuts down after 1 minute
Depends on which Koler. My old 5E got pissy if there was an air bubble in the coolant tank. If that is your issue there is a bleed screw on the opposite top side from the fill cap. Remove the fill cap, remove the bleed screw, fill the coolant till it comes out of the bleed screw, and then reassemble. If not that easy fix then the Kohler manual usually has a troubleshooting guide in it that can help with many issues.Current: 1998 Bayliner 4085 - Cummins 6BTA 370's
Past: 2004 Monterey 322 - Volvo 5.7 GXi's
Past: 1987 Silverton 34X - Crusader 454's
- Likes 1
I think that may be because the Generator senses its output voltage is too low or too high. Too low output may occur if there is a short in the coils and may be costly to repair. I hope that isn't the case for you. Frequency is also a reason for shutdown if output frequency is too low/high, again may be indicative of coil issues. I am not certain but would think that engine related issues (oil pressure, etc) would shut down the generator sooner. So, your problem is more likely to be electrical and/or controller related.
Good luckRetired, computer expert / executive
[email protected]
[email protected]
- Likes 1
Generator shuts down after 1-2 minutes and will repeat that again after sitting for 20-30 minutes, most likely issues and/or sensors:
- overheat (temp sensor)
- water flow at exhaust (temp sensor)
If it was doing this after 10-15 seconds, then it would more likely be an oil sensor or fuel related.
None of the older gensets have output related shutdowns (vlts / frequency) that I am aware of.Northport NY
- Likes 1
Originally posted by smitty477 View PostGenerator shuts down after 1-2 minutes and will repeat that again after sitting for 20-30 minutes, most likely issues and/or sensors:
None of the older gensets have output related shutdowns (vlts / frequency) that I am aware of.Ciera 2855 Sunridge
That would be one of the most common reasons.
Almost as common as not opening the sea valve to the water pump.
Gensets are typically fixed speeds and have a lot of water coming out under normal running conditions - if you do not have plenty of water at the exhaust outlet then it's a good place to start.
Here is video of this generator running. @44 sec you could hear that the speed is lowering for few seconds, the generator is doing that time to time, untill at one moment shuts off. Maybe those unexpected slowdowns tell anything about the sensors, or maybe it is about the auto chocking circuit?
https://youtu.be/kpy-PyGGSnECiera 2855 Sunridge
Originally posted by Sea_Cat_2855 View PostHere is video of this generator running. @44 sec you could hear that the speed is lowering for few seconds, the generator is doing that time to time, untill at one moment shuts off. Maybe those unexpected slowdowns tell anything about the sensors, or maybe it is about the auto chocking circuit?
Or .... is that happening with the genset main breaker(s) set to 'off' so that there can never be any loads on the genset?Northport NY
Originally posted by percs View PostThe impellor...maybe.
It sounds like a fuel filter externally or on the gen itself (my onan has both, one is a screen on the fuel pump) may be dirty/blocked.
When at rest enough fuel works it's way in and when the unit is on it uses that up and is starving for fuel.Ciera 2855 Sunridge
I'm going with fuel starvation issue that goes something like this. As the generator runs it sucks fuel in excess of what can pass through a remote fuel filter. The fuel line gradually gets sucked flat somewhere along the line and it dies. The drop in rpm that occurs reduces fuel draw and the line recovers somewhat and the generator speeds back up. RPM fluctuates while the line gradually finds its best state of collapse and then dead. Just a very wild guess.Tony Bacon,
Washougal, WA
Caspian, MMSI 338355743
1997 3788 Cummins 250hp
