Had a bad feeling I was running short of 8, did a compression check and sure enough I have a bad one.
Planning on pulling the valve cover and seeing if I can locate a stuck valve or bent rod etc.....anything else to check before pulling heads? The boat is in the slip, no trailer-- Has anyone pulled their heads while on the water?
I'm tempted to start tearing it down, but if I run into frozen bolts or other surprises it would get messy!
