Which plugs please? ​​​​​​​
    Which plugs please?
    1983 Mercruiser 260.
    I purchased the following tune up kit:
    https://marinepartssource.com/tune-up-kit-mmd-m57tbolt
    It came with BR6FS plugs. After reading on some forums, Some techs
    say it should have BR6EFS plugs in it. Old ones were thrown out so
    I'm not sure which ones are correct.
    Advise please.
    Thank you,
    Johnny
    This is a 1983 model year boat with a newer engine using the thunderbolt 4 ignition?
    Pre Vortec cylinder heads require the short reach plug (BR6FS), the Vortec cylinder head will require the long reach plug (BR6EFS).
    The NGK’s you’ve listed cross over to AC Delco MR43T and MR43LTS.
    Welcome to the club.
    "THE FIX"
    '93 2556
    Misc. projects thread
      Welcome! Getting the right plug is confusing at best partly because of plug development, fuels available and generation of the engine. Your merc 260 is probably a generation one small block, ie pre vortec. Here’s a link to the NGK codes and probably the best explanation I could find https://www.lsengineers.co.uk/blog/g...ng-system.html
      As I understand the difference, the EFS has an extended tip that’s going to go further into the combustion chamber, which is fine if that’s the way the heads were designed. Here’s where I have my doubts. Given the year of your engine I’m not sure that GM had gotten to the concept of getting the spark farther into the combustion chamber yet. I’m thinking the BR6FS is going to be the proper plug for your engine. However, hopefully there will be others that will either confirm what I’m thinking or address my well known intelligence deficiency.
        All good points, take heed!
        You will also want to gap the spark plugs according to your ignition system.
        With a standard ignition system, you can gap them at .032"/.035".
        If you have a high energy out put system, then you can gap them a bit greater.
        Don't forget to double check your ignition system spark advance. See what it's doing at around 3,200 RPM.
        Compare your findings to your OEM advance curve.
        When you do find the correct spark plugs, keep one of the boxes, open it up, flatten it out, and tape it into your log book.
        Rick E. Gresham, Oregon
          I had a 1984 260. It used the MR43T plugs. I am a retired engineer. I do not second guess other engineers, so i use whatever is innthe manual, which was the MR43T (AC delco). I had that boat 15 years and it ran great.
          Captharv 2001 2452
            It appears that BiggieJ entered briefly then left the building.
            "THE FIX"
            '93 2556
            • Nauti_Mike
              Nauti_Mike commented
              Where’s Elvis 🕺
