Monkey fur sourcing
    Monkey fur sourcing
    anyone knows the name of the fabric and where to buy some monkey fur? Have some stained pieces and can't seem feasible to clean - I tried bleach, alcohol, etc with little luck so at this point I'm really inclined on replacing it but can't seem to find anything locally, if any of you sourced some online I'd appreciate any pointers you might be able to provide. Thanks in advance.
    I had good luck with simple green. Now be aware, simple green will attack polycarbonate, don't get it on windows or engine gauges.
      Petco?
      Cheers, Hans
      2007 Carver 41 CMY
      Twin Volvo D6-370
      Montreal, Canada
      Midnight Sun I Photos
        Sailrite.com
        Fair Winds, Bill
          These threads may be helpful:
          https://www.baylinerownersclub.org/f...ur-replacement
          https://www.baylinerownersclub.org/f...adliner-carpet
          Possible source: http://rexpeggfabrics.com/index.php?...arine%7C110%7C
          Good luck.
          MV Dreams - 1999 3988
          330 Cummins
          Wrangell, AK
            Thanks guys - I was hoping there was some generic option rather than marine specialty, I guess I will have to look that way in the end, nothing urgent but I would def love if I can get something on there that doesn't carry stains accumulated over a 30 year period. I'll put a note here if I find anything that works besides the usual headliner replacements. Thanks again.
              You may try to search an RV storeā€¦. They offer headliner material for campers and trailers. Might be a bit less expensive.
                As Bill posted sailrite.com has almost everything.
                www.transferswitch4less.com
                Whats the weather like on our boat
                  Try: "Mildew stain and mold stain remover " by ZEP, sold at Home Depot. Try it as it comes, and if it does not work, add a small amout of bleach to it. Spray iy on, use a bristle brush to lightlt scrubn the material, then walk way fro an hour or two. Repeat as necessary.
                  For general cleaning of the fur, I have a carpet shampooer, with a "furnature wand". I use thier shampoo as directed. Sometimes needs two applications
                  Captharv 2001 2452
                    Just wondering.... has anyone tried a small steam cleaner to get mold off the monkey fur? Something like:
                    https://www.amazon.com/dp/B07C44DM6D..._it&pldnSite=1
                    330 Cummins
                    Wrangell, AK
                      The black might not be mold. On my boat it appears near crevices where air flow through occurs and its actually just dirt. The monkey fur becomes filter element material in those sections. I experimented by applying dish soap in water, very dilute, worked it in with terry cloth and vacuumed it out with wet/dry vac rinsing with clear water as I went. Cleaned right up! Since then I've been happy just knowing I can clean it when I get around to it. Might not ever get around to it but happy to know I could.
                      Tony Bacon,
                      Washougal, WA
                      Caspian, MMSI 338355743
                      1997 3788 Cummins 250hp
