1990 4588 helm volt meter shows house battery voltage when ignition off
    I recently purchase a 1990 4588 and this year when cruising noticed that the starboard volt meter for both the bridge and flybridge show the house batter voltage when the ignition of off. Is this typical? Or is there an electrical issue I need to investigate?
    This is normal (as designed) it allows you to monitor the house battery bank which is also charged by the starboard alternator. It is in the motoryacht owners manual among other items..if you don't have one you can download from Bayliner.
    Brad & Michelle
    Jet & Maverick
    1993 3688 "the Kraken"
    Hino W06 250HP
    14' Avon RIB, 50hp Tohatsu
    Moored at Shelter Bay
    LaConner, WA
      Thank you for the reply. I do have the owners manual, but didn't see that.
      • Pcpete
        Pcpete commented
        It’s buried in some detail at a point where one runs out of patience reading a technical document.
