PLEASE HELP SUPPORT OUR SITE
The idea of no WH taking up space sounds good at first glance. However, what is your plan for powering 120 V, 25 A, 3 KW while on the hook?
IMO:
25 Amps/ 3 KW is quite a full load even while on shore power.
25 Amps/ 3 KW is too much to ask of an Inverter and HLBB that would suit your boat.
25 Amps/ 3 KW is too much to ask of a small portable generator.
A good quality 2-way Marine HW should provide engine coolant heated water in about an hour (or less) while under way.
It should also hold warm/hot water over night.
These can be found with .75, 1.2 or 1.5 KW electric elements that a small portable generator will handle.
In either event, you'll not want to power resistance heat via an inverter.
Eric, I too have the Kohler 4 kw marine gen set, and it would be fully capable of operating that On-Demand WH.
Even with the capacity that I have, I'd not choose the On-Demand WH.
Here's my reasoning as to why!
With our 12 gallon 2-way WH we have:
increased our O/B water capacity by 12 gallons.
12 gallons of hot water when we reach our destination if it's 35-40 or more minutes out.
silent (minus the pump noise) hot water during the day. (warm towards the end of the day if we've used quite a bit)
silent (minus the pump noise) at least "warm to very warm" water in the morning.
Cost to have heated this.... ZERO.
If we end up needing to heat more water, we fire up the gen, or we take advantage of an outing.
Just offering some food for thought.
I like the idea and will be putting that in my boat when my water heater goes. I have a 6 gallon water heater now but with my boat being raw water cooled the engine never gets hot enough to warm the water in the water heater. Even if I could run the boat while on the hook for 40 minutes to get me warm water it is far cheaper to start the generator and heat the water by turning the water heater on. If you have a closed cooling you might consider running the engine each day while on the hook but it has a large cost.
My boat uses .7 gallon an hour at idle bump it up to 2000 rpm from 600 and we are at 1.0 gallons an hour. My generator 1 gallon 6 hours, the cost of fuel in the area I boat $6.08 a gallon do the math of a week and you won't be starting the engine. Not last summer but the summer before I spent 7 weeks on the boat and less than a week at a marine most places 5 days anchorded out some even longer. If I ran my boat for 30 hours to warm the water in my water heater that would cost $180.00 in fuel it's a no brainer for me.
seapuppy wrote:
holy crap....25 amps on a water heater???....that's almost your entire pwr allotment at the pole...
no..I'd stick with a standard water heater if it were me....
:arr arr
If I were to do something like this I would install a second 30amp service just for the water heater.
1998 3055 Ciera
(yes, a 1998)
Previous boat: 1993 3055
Sea Doo XP
Sea Doo GTI SE
No one suggested running your engine specifically for the purpose of heating water.
The suggestion was to take advantage of when you are running the engine, by using the closed loop that allows engine coolant to circulate through the WH's heat exchanger.
Use shore power when you can, and use the generator when you can.
If/when you take a short outing, the engine will additionally heat water.
Again Eric, with the On-Demand, there is no storage of heated water as there is with the conventional unit.
With the On-Demand, it must be powered or you'll have no hot water.
On shore power... no problem!
Coleman makes a great portable tankless water heater that would be perfect for a 26 footer. I have one and am planning on using it for my shower. It works great and does not draw any serious amperage. Here is a link to the unit on Amazon.
Alexirocz28 wrote:
1/2 hour??? REALLY!? I am very impressed!!!
It's it better to have 2 small 6 gallons or 1 big 12 gallons?
Tks you so much for the info....
Half hour.
Really.
You COULD install two 6 gallon tanks "in series" and you would have more hot water in nearly the same time interval (the hot "engine" water is not cooled much going through the heat exchanger loop in these small tanks), but keep in mind that fresh water storage is limited in most boats and that water is quite heavy to haul around. You would probably have difficulty finding room in our small boats to install two separate tanks.
Water in these electrically heated tanks can also be warmed up using a small Honda generator if you were at anchor.
2007 Discovery 246
300mpi BIII
Welcome island Lake Superior
On a crowded dock in the Summer that unit, at 25A continuous will be constantly popping the breaker. Great if you want your shower to turn cold half way through...
