Another good outlet is grooms engines from what I hear.
2655 5.7 repower-gctid341323
Guest repliedMy experience with Michigan Motorz has been good, as is their pricing.
Guest repliedchevrolet can suply marine engines !
Guest repliedyes it has allways been in freshwater.
Guest repliedCan I assume that you're in freshwater there?
If so, you can check the manifolds and risers, but they still may be OK. If you're in saltwater you're probably due.
I have a 1996 2655 with a mercruiser 5.7. I want to order a new long block. Where is the best place to order it from? I will be shipping it to Fort Worth Texas, the S/N for my motor is 0F792351. What else should I replace while I got the motor out?
Thanks,
Erich
