Drop in Volvo re-power
I think that most everyone's wife would blow a gasket or two.
Anyway, that is one sweet package. 😊
And, it is an AQ series drive with main suspension fork and pivot tube geometry! 👍
Check out the steering system!
It incorporates hydraulic cylinders that attach directly from the transom shield to the stern drive.
Rick E. Gresham, Oregon
Rick, you’ll need two. Better start preparing ya wife
🤣Dave
"THE FIX"
'93 2556
Misc. projects thread https://www.baylinerownersclub.org/f...56-gctid789773
Originally posted by 2850Bounty View PostI don’t have a wife! Does that mean I’ll be buying it?1997 Maxum 2400 SCR 5.7LX Bravo II
Very interesting manifold cooling setup. Seems to be individual exhaust tubes-header style (Equal length one would assume). Also there seems to be an integrated oil cooler setup on the back.
This is the most high performance setup I've seen from Volvo, if indeed it is stock.
Pretty cool.
Chay
Chay, that is a factory package, and I might add that it is a very well designed package.
And as I mentioned earlier, the best part is that it's among the AQ series family.
Unlike with the Volvo Penta SX or DP-S style:
No gimbal bearing
No rubber hub drive coupler
No annual alignment required
Larger footprint transom shield against the structural transom
Crankshaft driven seawater pump
Originally posted by 2850Bounty View Postthat is a factory package, and I might add that it is a very well designed package.
" WET EVER "
mmsi 338108404
mmsi 338124956
Originally posted by dktool View PostExcept for the fact that it appears it's a half closed cooling system with those bitchen headers being raw cooled.....
We can see what would appear to be multiple seawater supply ports at the bottom of each manifold, so why the fittings at the upper areas?
In other words, if the manifolds are Raw Water cooled, they would receive seawater at the bottom, then that seawater would exit with the exhaust gasses, not via the upper fitting..... yes/no?
I would think it's a "dry joint" arrangement, without more and clearer pictures it is "what looks like half closed to me"
Also, if it were full closed there would be a return line from each manifold to the H.E.
The individual lower inlets are the same as what Volvo has been doing with non-siamese manifolds for years.
Maybe look for drawings on marine parts Europe." WET EVER "
mmsi 338108404
mmsi 338124956
