1. My trim tabs dont work. Havent since I owned the boat (9 months). Dug into it today. Fixed a wiring issue, now thats all good. Got power to the switch. The switch is sending power back to the actuator. All power seems to be working like it should. The fluid was low, so I added to the full mark. Neither tab will move. At all. Suggestions? At least she rides fairly level and I don't need tabs to get up on plane. I hate stuff not working though.
2. Alternator Belts won't stay tight. I changed them, got them good and tight, but they are now loose again, after about only about 6 hours of running. Again, suggestions on keeping them tight? I looses all bolts to tighten, and then tighten all bolts to keep them there. When they get loose, they squeel when the alternator is under load.
These are not major ordeals, but have me a little baffled, and I know you guys have experienced everything known to boating.
Thanks!
Thanks!
