Hi guys. My OEM starter finally gave up. Installed a DB electric starter 3 weeks ago, worked great that night installed. Went down to take the boat out today, starter is toast. I've seen Rick post about an all steel gear reduction starter, where do I buy one?
Where to buy best starter? Mercruiser 5.7
DB sells BBQ Pork and Fried Rice starter motors. Most use a nylon planetary system ring gear.
Look at the Square Block starter motors. These are Spur Gear reduction...... and use all steel reduction gears.Rick E. Gresham, Oregon
When you install the starter did you verify the bolts had threads exposed through the mounts prior to installing? Sometimes the bolts end up with the non threads portion exposed which doesn’t pull the starter tight and can result in either the bolts to break or damage to the starter. Rick has some great pictures explaining this.1997 Maxum 2400 SCR 5.7LX Bravo II
It's on there tight, used the bolts supplied by DB , it worked great that night installed. The boat is in a covered slip with a bimini top over the back, bilge is dry. Rick, do you know a site I can buy a good starter or know a place locally ( I live 10 minutes from you)1996 Bayliner 2452, 5.7, A1G2. Needs a lot of work!
I’d like to know the details of the starter failure also. Like Mike asked, what exactly happened to the starter? What’s it doing? Clicking? Slow spinning? Grinding noise? Is the nose cone cracked or broken free? Could this be another issue like a faulty slave solenoid?
FWIW Ive had really good performance from my DB starter motor even with its nylon gear set. I also thought my DB starter failed but turns out the one failure I did have was due to me cranking through a hydrolock, wasn’t the starters fault. Maybe look into that as a possible cause.Dave
"THE FIX"
'93 2556
Misc. projects thread https://www.baylinerownersclub.org/f...56-gctid789773
First off, none of us should be using a Non-Gear reduction starter motor today. We are way past that!
Secondly, try your best to avoid using a HTGR/PMGR starter motor that incorporates a nylon ring gear.... they will not last, trust me.
These will typically look like this one:
Here is a what the industry began calling the "Square Block" starter motor. These are now listed in the category of Mini-Starter motors.
These use all steel spur gears for the reduction.... no nylon gears, period!
They incorporate a solenoid/lever action pinion gear/sprag clutch arrangement.... no Bendix Drive action!
The mounting bolt pattern allows us to use this motor for either the 153 or 168 tooth SBC ring gear flywheel.
The armature (on any of the HTGR/PMGR motors) will spin approx 3 X's faster than that of a Non-Gear reduction motor.
This creates more torque against the flywheel and therefor faster cranking speeds, all while drawing fewer Amps.
You can find this motor in the Marine version.
I installed these (in the Power Master brand) on my own twin SBC engine boat. They have worked flawlessly ever since.
FYI.... upon good and trusted authority (who will remain nameless), there is no difference between the automotive starter motors (of this style) and the Marine starter motors.
They are built identically in every respect.
The only difference is the certification and the price that we pay for one.
Do what you want with that info.
- 1 like
I read through a lot of these ads before buying an ARCO since that is locally available but they do have the plastic internal gear. I recall coming across an ad for a Mando PMGR starter that had all metal gears but can't find it. I wonder though if that internal gear is made of metal, could it be pot metal that is not really necessarily stronger than nylon?88 Four Winns 200 Horizon 4.3 OMC
Long Island Sound Region
Personally I have 4 DB pm htgr starters in active service in vehicles including my boat, never a problem but I like me some pork fried rice. YMMV
Upon initial read from the op the first thought I had was in line with what Dave eluded to later, a semi hydro-lock is a real issue to check.
When I hydro-locked years ago it was while using a DB.starter and it survived.
(disclaimer)
i carry a spare starter onboard for an offshore insurance policy.
Haven't seen it since I stowed it 9 years ago.
I would have one onboard regardless of what type / brand is currently mounted to the block. But that's just me being me.
" WET EVER "
mmsi 338108404
mmsi 338124956
Dave was right. I had drained manifolds and power steering cooler, then trusting advice from someone that should know better. I pulled anode on heat exchanger and hooked shop vac up with a rag, drains back in manifolds and P/S cooler. It sucked water up the exhaust and into the motor, I thought it was sucking through intake side, pulled drain on P/S cooler and sucked rest of water out. New crate motor May of last year. Got the boat home this morning pulled manifolds and plugs, motor turned smooth by hand, water shot out and soaked my leg, half the cylinders had water in them. Sprayed a bunch of wd40 in the cylinders and kept rotating. Flywheel looked good. One of the big red wires broke off the starter and was laying in bilge. I think the horrible grinding noise was starter eating itself. Planning to order a new starter, install with new gaskets on manifolds and risers. Get it running then change the oil.1996 Bayliner 2452, 5.7, A1G2. Needs a lot of work!
Oh boy😳
Not really understanding how the shop vac pulled water into the cylinders, was she moored during that process? That might do it.
Regardless, with the discovery of water in the cylinders I’d suggest you get the engine running sooner than later to burn off any moisture in there.
Sorry to hear about this, not very Christmasy....Dave
"THE FIX"
'93 2556
