Transom oil pipe size-gctid352028
    Hi
    Removed all the bellows etc today and had to cut through the braided oil pipe, on all the bellows kits that you can buy they don't seem to supply the oil pipe!!! What size is the pipe?
    i've found the length needed from the manual but thats all.
    Regards.
    Hi
    Matched the pipe and it turns out to be fuel line size.
      Any hydraulics shop or auto supply that can make hydraulic lines would be able to size the tubing and make one.
