Hi
Working on replacing my Gimbal area and when removing my trim switches i found that the one of the wires had been cut. The wires from the Port trim limit switch has two wires with male ends which join two wires one with blue and white and the other purple and white, the blue and white heads to the trim pump but the purple and white that heads forward with the loom has been cut at some time. Anyone know what the wire does and any reason why it has beeen cut.
Also found that the end of the shift bellows had no clip on it !!
Any help appreciated.
