Hi,
I just had a remanufactured engine installed to my 1998 2452 so the old one was winched out and a remanufactured one winched in. Maybe before and possibly during the process the wiring harness or a connection has given up the ghost.
I can "hot wire" the engine by supplying 12v directly to the coil and the engine runs really well like this. I have the wiring diagram courtesy of manual 24. However, I am getting a little confused over the role or the oil pressure sender and alternator and other "interlocking" elements that supply current to the coil.
I wonder if anyone has seen an explanation that starts something like "when the owner cranks the engine the oil pressure sender prevents starting until oil pressure builds up". I suspect this sort of explanation will help me locate the offending wire or connector. The wiring diagram is really difficult to understand without the 'design-intent' of whoever designed it.
Can anyone help please?
Terry
Terry
