torque specs for the AQ125 engine.
    Good day to all.Reay to go back together with engines, AQ125b. Does anyone out there have a complete spec sheet for the torque numbers for a AQ125b Engine, head bolts, rods, main bearing, ect.
    Thxs'Catbaby.
    This is from Claymer's Volvo Shop Manual.
      Use caution when referring to the Clymers or Seloc manuals. They are known to have errors in some of the specifications.
      Rick E. Gresham, Oregon
        What I did was I bought a Volvo Aq125 B manual...hope it was right! Now working on outdrives...what is the best process for painting these. I have them sanded smooth but not stripped to the metal.
        It would be a lot of work to strip to the metal but if its best i will do it. So primer and finish coat? What primer is best and what finish coat is best.
        Thanks Catbaby
          If it's the OEM Volvo Penta (and not Clymers or Seloc), you'll be OK.
          That is good.
          You'll want to leave as much of the OEM finish as possible. (it doesn't get any better than what the factory did!)
          See above!
          A thin coating of Zinc Chromate for any bare aluminum areas ONLY.
          I've have good results in the past using a custom color mixed two-part industrial epoxy.
          Make sure that you bring the aluminum up to above "dew point" temperature before applying.
            sounds good! I love the thoughts of an epoxy finish! Questions would it be wrong to prime over the painted surfaces?? Just asking.
            Catbaby.
              A light coating of Zinc Chromate would be for any bare aluminum only!
              I have not used any of the epoxy with a primer on the original finish.
              The key to a good application is bringing the aluminum up to above “dewpoint“ temperature.
                thanks again I am stuck trying to the get the the steering casing nut out has 2 hex head bolts, the two holes one on the right one on the left how in the world do you get this out!!
                Catbaby
                  I do not know what you are referring to. Perhaps post a few pictures.
                    ok here you go.
                    catbaby
                      i sent a picture YES!!! what a thrill
                      Catbaby
                        ok here you go.
                        catbaby
                        That is your double bolt helmet pin. (above, they are calling it a steering pin)
                        The two smaller holes at 9:00 O'clock and 3:00 O'clock are threaded jack bolt holes.
                        Spray some WD40 or _____ into the holes and blast them out with compressed air.
                        Make sure that the threads are nice and clean!
                        Lube the holes with grease.
                        NOTE: some of these are Metric 6mm, and some are US 1/4" NC.
                        Most that I've worked with are 1/4" NC
                        Use bolts with plenty of thread length.
                        Run the correct grade # 8 bolt into each hole.......(use grade #8)
                        Begin to tighten them equally and keep going. .
                        The two bolts will jack the pin out of the bore.
                        NOTE:
                        The two 3/8" NC cap screws that secure the helmet pin must not exceed the depth of the female threads.
                        If they do exceed the depth, they will break the ends of the threaded bores, and will allow water to enter the universal shaft area.
                        I've seen this all too often where a DIYr used the wrong length cap screws, and broke the aluminum open.
                          Just wanted you to know that i got it out!
                          I never could get the bolts to tighten in. So I took a 5/16 die threaded as much as I could, tighten a 5/16 bolt in and put the slide hammer too it!! Popped right out.
                          After I got it out it look like I never did get cleaned to the threads. There some kind of filler in the hold. I am soaking it in MM oil for few days...that should free it up.
                          Now it feels like the universal joint is seized on the drive shaft. Looking at my drawings is looks like I have disconnected everything.
                          it should slide right off....right?
                          Catbaby
                            These double bolt helmet pin cap screws are 3/8" NC, and the jack screw threads are 1/4".
                            Where are you seeing 5/16"?
                            Inside of the threaded holes of the aluminum clamping collar?????
                            If so, I would look at the underside of that area and check to see if the aluminum has been broken out by a cap screw of the wrong length.
                            Are you suggesting that the universal drive shaft's female yoke may be stuck onto the PDS?
                            Yes, the universal drive shaft's female yoke should slide AFT and out.
                            If it does not, then you have rust/corrosion that is preventing it from sliding off of the PDS splines.
                            If this is the case, post back. I have a few suggestions that may help.
                              the jack screw holes had been filled with something I could not reach the threads. After it was out I cleaned it from the back side and found the threads to b 1/4 20. But because of the filler I could not reach the threads with a screw or bolt. WD 40 would not melt the filler..... The same jack screw hole is where I threaded in my 5/16 screw threads...the 3/8 double bolt helmet pin cap screws are untouched....there is no damage done.
                              As i thought the rust and corrosion is keeping the universal joint from sliding off...soaked down with Kano Labs Silikroil this good stuff.
                              looking forward to hearing from you.
                              Catbaby
