Omc outdrive
    Omc outdrive
    are all lower units 86 and up the same? I have an 89 5.0 ford 302 outdrive that I was thinking of using lower unit and changing gears in upper case with my 5.7 gears. My case is shot from electrolysis. Thoughts?
    1987 bayliner 2550 5.7 omc cobra i/o
    Yes, all V6 and V8 lowers (large bullet) are the same, as you stated the ratio difference is determined by the upper gear set.
    " WET EVER "
    mmsi 338108404
    mmsi 338124956
      How do I know if its a large?
        You have the 5.7 drive already ? if yes the drives are the the same interchangeable ... gears will be slighty different you can make it work with a prop tweak, in other words different prop say you have now a 19p you may have to go lower 2 degrees or more, some shops allow you to test props as long as you buy one from them the key is staying within recommended rpm at wot do not exceed capiche !
          FYI:
          ...... The engine HP/Torque (with some influence of the hull size/weight) determines the final gear reduction.
          ...... It is nearly impossible to prop ourselves out of an incorrect reduction.
          ...... Prop pitch is measured in inches, not degrees.
          Rick E. Gresham, Oregon
            If my research is correct the 5.0 Ford is 21:18 and the 5.7 is 21:15.
              With the hull you have ...... use the correct ratio upper and if everything else is in good order the prop that will work best is a 15-1/2 x 15
              " WET EVER "
              mmsi 338108404
              mmsi 338124956
                I have the same prop (15.5x15) on my '88 4.3-4bbl Cobra for a 20' boat, the performance with it is excellent.
                Long Island Sound Region
                  those numbers convert to overall ratios of approx. 1.50:1 and 1.41:1, respectively.
                  But as noted for the large case lower units, all of them have the 14:26 gearing, the only different lower unit was on the early 2.3 and 3.0s (small case) these were 13:6 and the 460 Ford, (extra large case) this was 17:30
                  for the uppers its:
                  21:17 for the 5.0, 21:16 for the 5.7, as noted the lowers are the same.
                    21-16 gear set is the correct ratio for 5.7L at less than 5000 ft operating elevation.
                    " WET EVER "
                    mmsi 338108404
                    mmsi 338124956
                      How do i measure lower unit to see if this one i bought will work? According to prop number its for a 4 3/4 case. It has minor up and down movement at prop and normal fore and aft movement
                        Looks like the one I pulled is a 1.6 ratio as every 8 turns of driveshaft there's 5 prop revolutions
                          Is it possible to use this with prop change or do I need to change gears?
                            Remove the top cover and count the teeth, see what it truly is.
                            " WET EVER "
                            mmsi 338108404
                            mmsi 338124956
