Help identifying parts
    what is this? It has wire going to it and my old float switch was zip tied to it
    Also in second pic what are these wires for. They aren't connected to anything and are frayed. goes through transom near water inlet for power steering cooler on omc cobra. The boot that seals the transition from outside to inside the boat leaks sometimes
    1987 bayliner 2550 5.7 omc cobra i/o
    Trim /tilt sensor wiring? The thin wire hanging down on the left side.
      That looks like it but I don't have a tilt trim guage on my boat. Its not hooked up on the inside either
        First picture looks like a in hull transducer. I don’t think OMC had a trim limit switch so it’s probably the wiring for a trim position gauge even though you don’t have that option.
        • dktool
          dktool commented
          Correct on both counts.
        I'll have to trace where the transducer cable goes to see if its in use. I have 2 more outside the boat one I know is not in use. Thank you everyone
