Sourcing 2859 Wiper Motor and Arm
    New-ish here, so apologizes in advance. Looking to buy a motor and blade for my (new to me) 2000 2859. Entire unit is missing. Prior owner said motor died, he removed to replace and now he can't find it. No blade or arm either.
    Reviewing posts here leads me to AM Equipment, so I suspect they provided the motors/assembly. Any offer specifics on what I need to order - motor/arm/blade? Suggestions on other place to buy?
    Thanks in advance.
    2000 2859
    Merritt Island, Fl
    Yes, AM equipment is the vendor. However, you will need to order the Pantograph adapter(attaches to the deck and the arm). Be sure to measure the shaft length of what attaches to your wiper arm. I believe the 2859 is the 1.25 inch, but you need to measure. As it turned out, I did not need to motor, just the 230 series Pantograph Adapter. You should remove the deck mounted Pantograph and see if the motor is really bad. Www.amequipment.com.
    Dave Stancil
    Bayliner #1 in slip
    1993 2859 Classic
    10 ' dingy w/4HP 2012 DS4 Suzuki
    Bayliner #2 in garage
    2000 19.5 Capri Classic on trailer
