Steering cable replacement bayliner 2556
    Probably discussed before but her we goes. Will change cables and pinion on both bridge and cabin. Getting the cable out of the hole on the fly bridge was hard, but when first routing it through the inspection hatch it was much easier( see the picture). Can also confirm both cables are identical length and if understand the marking correctly its 21ft. Now only need to find a cheap online shop to buy 2 full sets. Actually would like to go to hydraulic but too expensive this time, spending so much on this I don't even want to count.....
    Click image for larger version  Name:	IMG_20200328_153800.jpg Views:	0 Size:	155.0 KB ID:	568365Click image for larger version  Name:	IMG_20200328_162112.jpg Views:	0 Size:	326.4 KB ID:	568366Click image for larger version  Name:	IMG_20200328_162135.jpg Views:	0 Size:	265.5 KB ID:	568367
    Bayliner 2556 1990 project
    Hi,
    trying to do the same right now.
    Question: how did you removed the lines from the direction block in the engine bay ?
Name:	Sans titre.png
    I did unscrew the nut but it is impossible to pull the rod out.
    Thanks for your help.
      You’ve pulled the pins at the end of the rods? If so and they are seized you may need to apply some penetrating oil along with some heat to break them free.
      Click image for larger version  Name:	731772C3-1EC6-48E7-A4A8-6C26F6041DC0.jpeg Views:	4 Size:	2.88 MB ID:	590585
      "THE FIX"
      '93 2556
      Misc. projects thread
        OK.....Might have missed that 😒
        As always, thanks for your precious help Dave.
          Should be able to see the end of the cables there also. They could be rusted up in there. Click image for larger version
          "THE FIX"
          '93 2556
